Re: Force 85 - Can't adjust fuel mixture
I just put it in gear on the water, in the middle of a quiet lake, and turned each idle jet in until the idle missed then back out a little. I did all three like that and did it over maybe three or four times. This was as lean as I could get it because they stink so bad trolling. Then I opened each just a hair, like less than 1/8 turn. I have run it since I think '03 like that, it had new plugs at the time and they are champion but I forget the number. They are still in it, but I don't put many hours on it. Thing is a tank, always starts right up in the spring and never had a problem with it.
I've done a lot of old motors this way, it is proper to set idle under load and that would be trolling with an outboard at idle. Most of them you need to turn out more though, so they don't kill when you put them in gear depending on how low they drop when you shift...and some will kill repeatedly when cold if you don't add a quarter turn or so. Even the weather would change the mix of a Merc I had, but nothing seems to bother this force. Even if I open the jets 2 turns it idles about the same. It never loads up but will miss a little when you take off after a long troll....long would be maybe a mile since I don't troll fishing with it.
I also had a clamp on digital tach and set the idle speed when I did the jets.
I suppose even though this is a diy type forum, if you are not familiar with engines then read up more about it. If you open them more and have it rich it will not hurt anything, just maybe foul plugs and load up after extended idle. If you run it too lean that could be bad. I would not turn them in far as a good smooth idle allows and leave it there, you must have it richer than that and turn them out some.
The reason I do it this way instead of X turns, is because once in a while a needle jet can get screwed up maybe because someone hard seats it. Then it may be different, in that case with a multiple carb engine it would not have the same mixtures. If I do it this way I know each carb is getting the same mixture to start with, then richen it up a little. It may come out to the same spot as a manual says and it often does.
