Re: Adjusting idle on 85 hp force
The idle is set with the timing arm like many older outboards. I got mine around the right speed, then in gear on the lake I set all the idle mix jets low as I could without it dying, one at a time. I then opened them just a hair, and set the idle to where it would just stay running when put in gear at a stop. Then turned idle up just a hair. It has been fine that way. The Mercs I have run had to be set differently, more rich at idle, and they would change with the weather (get more rich hotter weather). These stink so much I set it lean as I could, but it does not appear to care the Mercs would die out at times and this does not. Mine is an '83 I assume it is the same with the three carbs. I cleaned them first and put new plugs in.
Most all these old OB I have seen the idle is in the carb and you can't change it. They retard the timing to idle it down that keeps a smooth idle and airflow in the motor. When you see the timing arm stop and throttle starts to open (about at a faster trolling speed), that is actually idling on the carbs, lower rpm than that is wasting fuel with a under timed motor. But that is the way they idle slow the best.
