Re: Force 120 steering froze up
zkidd you should start your own thread so you can get more personal help.
re613 I'm not sure I follow your question. Anyways, if the steering is freezing or getting stuck, you first need to isolate which part or section is causing it, i.e. is it the steering cable, tube or the steering mechanism (rack & pinion) with the steering wheel or is it the engine kingpost? By disconnecting the engine steering link rod, you should be able to tell which part is causing the hard steering.
When disconnected and the steering is still hard, then it is obvious the problem is with the steering mechanism, i,e, from the steering tube all the way back to the steering wheel's rack & pinion (if such is the system). If steering is easy when disconnected, most likely the problem is with the engine kingpost which probably need some cleaning. I clean mine without disassembly by heating it with a heat gun with zerk fitting removed and shooting it with WD 40 to remove old grease. Let it cool and re-shoot with new waterproof grease. With the link rod disconnected you can manually turn the engine with ease if the kingpost is not frozen.
