Re: Step By Step timing For a 120 hp force
Follow me through.
The flywheel rotates clockwise so the first mark that you see that crosses the mark on the crankase would be the most advanced timing possible. In your case it is marked 40 degrees which would be 40 deg Before Top Dead Center BTDC. The last mark on the flywheel, which should be separated from the other marks will be the 0 or Top Dead Center TDC mark.
You want to set your timing at 28 or 30 degrees BTDC using the starter with the trottle at WOT. This will give you 30 or 32 degrees BTDC running at WOT. You will need to jumper the neutral safety switch to do this.
If your idle link and sync adjusment is correct, you will seel 0deg to -2deg using the starter with the trottle at neutral.
If you read 28 with the trottle at WOT, you were reading 28deg BTDC. You can leave it there or adjust the additional 2 degrees. Don't go any further as the gasohol we are using today does not have the anti-knock qualities that earlier gasoline did.
Since you had an earlier meltdown, best leave it at 28. Also, when adjusting your carbs, don't go below 1 turn out for the same reasons.
Did this help,
John
