Had to replace bearing housing behind the prop was leaking oil removed prop and saw cracks. Bought new part installed it with old bearing race as per mechanic said it and bearing wear fine. After installing the housing it seems that the prop doe not turn very freely it has some resistance to it in neutral shifts into foward and revers fine but just seems really tight to turn by hand. I have not put the boat into the water yet or ran the engine am I just being paranoid or is the something else I should be looking for. Any help would be great.
