Re: 85 HP Force outboard-random loss of power
First of all, buy a Clymer Force Shop manual off of ebay or Amazon or Barnes and Noble. Believe me, it wouldn't be a waste of money.
The thing with the filter screen on it is the fuel pump housing. When you remove the six screws, the housing will come off along with the fuel pump diaphram and gasket. If you have never seen a diaphram fuel pump, it is a piece of rubber that is shaped like a snowman.
I strongly suggest that you replace the three check valves inside the fuel pump housing as well. Due to Gasahol, the poppets on these valves are swelling and starting to stick. The new valves have a different material and it doesn't swell.
The fuel pump kit is somewhere around $22 and the check valves cost $5 each.
You can get parts from iboats,
www.crowleymarine.com and
www.mercruiserparts.com
John
