I need a flywheel and stator for my 70 hp force. sn# OE088968. I think it is a 1994. I have the flywheel and stator off the stator is not a problem cause I can match it up on several sites exactly. the stator is a CDI #174-9710K1, which is the 16 amp stator.
My problem is the flywheel, the numbers I have found on it are 43 817409 on top, underneath are several others: CC2146, 21B4, and KIC4.
I have found diaghrams that show flywheels numbered 859241T2 ,T4,T8, or T10. does the number after the "T" matter or can I use any opf these flywheels?
Also is there a serial number directly on the engine block or is the number I gave above the engine serial number, I kfound this number on the side of the motor mount.
Thank you
Thank you
