Outboardretard
- Jul 11, 2009
- 2
Ahh the webs we weave when we don't have the manual to read! Been having shifting problems with model# 1258V6A, ever since I removed the pivot screw to drain the L/U. The problem occurs when trying reverse in the water, it won't begin to engage until the throttle is 1/2 way back, at which point she is revving pretty good. I took to a mech and with out removing the L/U he was leaning towards a torn up Shift dog. So I bought a manual, and realized that both times I have changed the lube I shouldn't have removed the pivot screw! Both times have had no problems getting the pivot screw back in. I have noticed that the shift rod that disappears underneath the bottom carb has about a 1/8inch of play up and down.
Fwd seems to be almost perfect, maybe a tad bit too far fwd before it engages. But once I'm engaged in fwd, she'll stay there all day if I dont move it. She runs strong and fast. Is just kind of embarrassing not having reverse in certain situations.
Reverse, I think if I remember correctly I can engage it with the motor off, and start it up, but it is going too fast in reverse for me to trust it from a dead start. So I don't often try.
Final question with the pivot screw. Will it only go back in, in one position, or will it engage in multiple positions after removal with linkage undisturbed, possibly explaining why reverse is a pain to get into? Thanks for your time.
