Hey,
I have looked everwhere for these the two gears in the motor leg of my Chrysler. I am having to keep form fishing because of two gears! They have teeth missing on each. The same gears were used by Chrysler on all 252HB models. The part numbers are below:
FA413815
GEAR, STEERING HANDLE W/SET SCREW FOR MANUAL START MODELS
F288691
GEAR, MAGNETO CONTROL SHAFT FOR MANUAL START MODELS
You can see them as part number 53 and 55 on the webpage below:
http://www.marinepartsplus.com/catalog/chrysler/serial/25_1975_/FOB1983-1/1726-140
With the teeth missing, I am not able to adjust my speed. I go from zero to sixty in about 3 seconds. If anyone knows how I can get these gears , or the whole motor leg, whatever it takes to get the gears... PLEASE HELP.
FA413815
F288691
