Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
water pump question on 1987 force 50
  • water pump question on 1987 force 50
    How can I tell if the water pump is working on my 1987 force 50 hp? Where does the water spray out?
    Re: water pump question on 1987 force 50
    There should be a spray coming out of the exhaust. Check out the add a tell tail thread. If the water pump has not been change in a long time it would not be a bad idea to replace it.
    Canada more square miles of awesomeness per person than any other country on earth.
    • #3
      Does a 1987 force 50 not spray out a stream from the back hole like other outboards?
      1967 WestWind "Aerodyne" 14' Runabout
      sigpic
      Just Keep N it Reel!!!
      My restoration in progress
      • #4
        no there is no back hole in these motors
        • #5
          I acquired a 1987 50hp model# 507X7B, have not fired it up yet but it does have a round hole in the back just like a spray stream hole, is this just for show?
          sigpic
          • #6
            thats the exhaust
            • #7
              There should be like a good mist coming out of that hole. These engines never had a tell tail like other models/makes. A tell tail can be installed cheap.
