I just recently purchased a used bayliner that came with a Force 120 and a small Mercury kicker. I took it out today and a couple of hours after tubing around the lake, the motor started acting up.
When you start the motor in neutral it will start just fine but as soon as you put it in gear and you start pushing forward you can feel it struggle and then it quits. It did that every single time so after like 20 times I thought it was time to bring her home. An alarm has also gone off from time to time until I killed the ignition. Don't know what that was either.
Please help. Thank you.
