GBOverKill
- Mar 17, 2009
- 26
Hi Folks,
I've read alot of the previous posts on here and done just about everything, I'm stumped. I'm on vacation next week and planned on doing alot of tubing, etc. with the family. The engine has run perfectly the last dozen times I've had it out this year.
Here's what happened....the other day I was out running at WOT when all of the sudden the motor slowly lost power grrrrrr....grrrr....gr..and died. I was able to restart and get back to the docks but only what seemed to be about 1/2 power (rpms & speed).
Here's what I've done so far...
-Checked the fuel system and replaced inline filter, cleared the tank vent. Seems to be getting plenty of fuel.
-Replaced all the spark plugs (although they all looked fine).
-Checked for spark and have spark on all 4 cylinders.
-Checked compression and it's good on all 4 cylinders (130-140psi).
-All wires under the cowl appear normal and connected.
My mechanic (which unfortunately is 2 hours away) suggested spraying some carb cleaner in each carb; which I will try today.
Any other ideas????
Any other ideas????
