Problem 1:
Choke solenoid gives only a little nudge when I push the key. BUT... If I give it a little help by pushing the plunger it only a fraction of an inch, it will engage all the way every time, and engage the choke. I was just going to go ahead and order a new solenoid, but figured I would ask you experts first if there something I should adjust or check first because although the pasrt s only $37, shipping is $42 to Canada!. Because it does work, but like I said, only if I dont let it come all the way back. (what I have done for now is adjust the little rod on the carb so the lunger never returns all the way) Works like that, but it's obviously not ideal.
Problem 2:
Sticking controls. I can go from Neutral to high idle setting easy enough, but when I engage it into gear, it takes alot of force on the control. Once it clunks in there it adjusts fine until I try and go the other way back to reverse. Theres a sticking point there I've looked at the mechanisms like under the flywheel and to the side of the motor but theres nothing noticable.
What should I check?
Thanks in advance!!
Problem 2:
Thanks in advance!!
