Hello,
I have an old Chrysler 50 which I believe to be about 1966 as it looks the same as a Westbend 45. This engine was purchased used and had been repainted and decals installed so it could be anything. I know it was purchased as a Chrysler as I bought it from a friend whose father had it new and used it for one summer and then sold the boat but kept the engine. His son took the engine and put it on a boat he had for two weeks after painting it up.
This engine is in great shape and only has two summers use on it in 40 + years.
The leg oil is empty and I wanted to fill it up but see that there are three holes in the leg at the bottom. I know I will need to fill it from the bottom but was cautioned about pulling one of the screws as it apparently locks the shaft???
I may also need to replaced the gaskets prior to refilling. Can anybody point me to a link with the information I need to do this or give me some suggestions?
Cheers,
Cheers,
