I have a 1973 Chrysler 85hp outboard that would start after a few tries and run fine at high speeds. But it was consistently stalling at low idle and running speeds. Attempting to fix this, I decided to replace the fuel filter diaphragm which looked to be the original. It was distorted and had some stress marks around the edge of it.
Everything back together and now it fails to start. Correction, I got it to start twice for a brief period but then nothing again.
Nothing else has changed to my knowledge. Is it possible that I installed it incorrectly? Could I have put the diaphragm on upside down, or got some debris in the line?
The engine turns over all day. Plugs are new and I have spark. Cylinder 2 had some oil fouling which I hoped to resolve with the new diaphragm. It has new fuel and it flows to the fuel pump and fills the carburetor bowls.
I have scoured the iBoats forum for similar issues with no luck. Any suggestions or thoughts will be appreciated. Thanks in advance!
