rbtroutguy
- Mar 18, 2009
- 4
I took apart the lower unit of my '68 Chrysler 45hp outboard to reset the shift pivot screw and check the bearings. While removing the lower unit, I destroyed the lower unit black gasket. Are these available anywhere, or can I use silicone caulk to make my own gasket. Also, does this gasket separate oil from water at any point, or would I be able to just seal the outside? This is my first attempt at this, so any advice is appreciated. Thanks! rbtroutguy
