First let me say that I've been browsing through these forums for some time now and have found a wealth of knowledge on here. This is a very informative site, especially for a newbie like me.
Now to my issue.
Went out saturday afternoon and shortly after getting out of the "idle wake" zone we get on the gas and almost instantly notice that the somethings not right. the motor sounded like it was firing properly. the motor wasn't knocking or anything but it would lose a little power every few seconds, almost like it was hesitating. We were still able to cruise around 35mph. We didn't notice the issue when going at slower speeds.
So we get the boat back home and started checking the simple things, looking for loose wires, checking the pugs and water separator. It didn't take long to find the problem. The top spark plug wire just about came off on its own when I went to check the spark plug. The top of the spark plug was brown and the inside of the boot itself was filthy. The spark plugs are less than 2mo and the other 3 looked nice and clean and the boots were perfect as well. Also, the back part of the boot that attached to the wire had a bunch of black gunk oozing out when you pinch it.
So now the question is can we just replace the boot or do we need to replace the entire wire/coil set?
I appreciate any advice. Thanks! Ed
Now to my issue.
