I am cleaning carb. Was taking apart, then it says back off main nozzle. Picture looks like it is a screw. I look in turret and see a head with a slot in it. It has a pin sticking out of it. So I can not use a screw driver.Is this the Main nozzle? If so how do you get it off. Book says, back off then remove from turret. How do you back off. I think I am just missing the main nozzle. It is about 1/4 inch lower then main jet screw. Did someone just put it in too deep?
