Hi guys I am new here finding this forum on Google after looking for information on a new "Project" I got myself into. I picked up a 85 19ft Bayliner BR with the Force 125 engine in pretty rough shape. I can see it needs a new deck and the interior is pretty beat up. Before I decide to take on this project I need to get the motor running and check its condition otherwise the whole thing is scrap.
The guy I got the boat from said that it has not been in the water in 2 years but he had it started earlier this year in the yard with muffs on. When I went to look at it he couldnt get it started because there seems to be a problem with the electrical system. The motor wouldnt do anything when he turned the key. The battery was good and had a full charge. We checked the obvious things like proper battery connections and he looked at some fuses. Everything appeared to be as it should be. He mentioned that he seems to remember replacing the ignition/key switch a few years ago when he had a similiar problem and that is probably what has happened again? Sound possible or more like bull? How can I troubleshoot this switch?
I have a test light and a voltmeter but I am not sure what I am looking for. I have wrenched on some cars in my day but never boats. Is there a way to "jump" the motor so to speak and bypass the switch like on the old fords? This way I could atleast make sure the engine runs before I move on with this project.
Another question if you dont mind. The very bottom of the motor below the propellor has been repaired. I am not sure what the part is called I think the "skeg"? It appears that at one time he must have hit something because the prop is new and there is a repair at the very bottom portion of the engine casting. He said it had been that way for years and it never caused a problem. Is this a serious problem?
I have ordered a manual for this engine online but it will be a few days before it arrives and I was hoping to get this motor running this weekend.
Thanks in advance for your time.
Rc
Rc
