1989capriforce50
- Oct 12, 2008
- 1
when i sink the outboard into a garbage can to flush the motor after saltwater use, (the next day, so it had 24 hours to cool off(, i takes about 30 seconds in idle to spit out exhaust with spray out the two vertical pencil holes. the water spray is not that heavy and it turnes extremly hot after about 2 minutes of running...cold water is being cycled through garbage can through hose. so my question is, do i need new impeller or waterpump? how much should i expect a marine motor place to charge for? help. thanks
