When the boat is out of the water and you put the (water muffs) not sure the correct name. The things the hose connects to and is placed around the lower unit. Is there suppose to be water coming out some place else so I can tell that it is cooling? I place the motor in a trash can first and fired it up but couldnt see water come out any where and the high temp alarm never sounded. Then drained the can and tryed the muffs and still never seen any water and never heard alarm sound.
