Re: Chrysler - 1977 65hp - help with starter
Dale: That series of 55,60,65 engies was a separate series and used a different starter than all other mid to large Chrysler engines.
If I am correct, your engine is a 2 cylinder 2 carb engine.
I hate to be the bearer of bad news---but---
It most likely has a MAGNA-POWER II ignition system. Putting it politely, this ignition was a piece of crap. It was so bad and failed so regularly that Chrysler offered a retro fit kit.
Before you invest ANY money into this engine, hook up the electrical and rope start it to see if it has spark. If it has no spark, sell it. Parts are not available to either convert this ignition or to repair it. You might be able to find used parts at The Chrysler Crew and convert to Prestolite ignition but that's a lot of work and cost--even used. While the engine block itself was a beauty and really well engineered, the ignition may give you heartaches. Magna Power II was spotty--many failed but some ran forever. This series engines also had problems with the lower units. The gears were too small for the power and also could fail if abused at all. They would last well unless a smaller prop was used and a full throttle hole shot was performed. Then the engine developed power so fast that it overloaded the gears and stripped them. So if you do get it running be sure to use a higher pitched prop (around 10 3/8 X 13) and try not to nail it. Full throttle runs are not a problem, just quick acceleration hole shots.
If it has spark and you decide you want a starter, send me a private message--I have 2 plus some other parts..
