Re: Force 50 Where to find serial or model number
Bill,
What worked for me is the following:
1. Take a wide tipped magic marker and a paper towel to the motor.
2. Mark over the top line of the number plate with the magic marker, then immediately scrub the ink off with the paper towel.
3. Move on down repeating the above on the serial number, horsepower/rpm line, etc.
4. If you cannot read a line, repeat the above.
5. Finally, if you still cannot read all of the numbers, take a small penlight and hold it at a very low angle to the plate. The numbers should be visible.
Rodsailor
