IndyNurseRuthie
- Aug 6, 2008
- 2
SOS!
I had my boat out on Lake Michigan, with 1-2 foot waves when I went out (the marine forecast was WAY off). The wind picked up just after dark and when the 3-5 foot waves started pushing me dangerously close to a large stone sea-wall, I panicked and put my boat in reverse and put the throttle down pretty hard (I was fighting the waves).
When a wave came at me and nearly capsized my boat, I decided to make a U-turn and took the boat from reverse to forward in one quick motion with the throttle still down nearly all the way. When I did this, I heard a screeching sound for 4-5 seconds and I immediately turned the engine off. When I tried to restart the engine a minute or so later, it wouldn't start (was just turning over like it does when you try to start it with the boat in gear. Fortunately, a lone boat came my way (everyone else had the good sense to make a run for the harbor when the waves kicked up). After I was towed safely back to the marina, I took a look at the shifter cable and noticed it is "looser" than usual. Where you can normally pull the shifter cable in and out (near the engine) and hear the "click" when it changes from neutral to reverse, there is now NO click - it's smooth and has less resistance when I move the shifter cable in and out where it comes off the engine. (This part of the shifter cable normally has more resistance and clicks when it is moved forward or backward.)
Dr. Force, are you out there? What on earth did I do? Am I doomed to major repairs or is it possible that something smaller has broken or become disconnected or maladjusted? Where do you suggest that I begin looking? I have the Seloc manual for my engine, which has been very helpful. Does anyone recommend getting the Clymer one? Is it substantially better?
I am no mechanic, but I have done quite a bit of work on this motor in the past - routine maintenance stuff (impeller replacement, etc.), thermostat replacement, troubleshooting starting system and solenoid replacement, etc.
I'm just trying to figure out what places to start looking to assess the damage.
Thanks for any info anyone can give me!
