Was out on lake pulling kids on tube for about an hour the other day and idled down to switch riders which took about 15 minutes (14 minutes longer than assumed) so the engine was still idling. When attempting to go to full throttle, engine would only power up to about 1/3 of what it had been.
Gimped back to dock and trailered home. Checked the plugs and they seemed a bit grimy, but all seemed to a dark color with signs of fuel. Cleaned plugs and went back out with same result. Came back, checked the compression and had ~120 lbs. plus or minus less than 3 lbs. on each of the 3 cylinders - is that good, fair or poor???)
Side note - have always wondered whether this motor was ever hitting top end with respect to rpms. Does not have a tach hooked up so don't know what the high end rpms were, but now can barely get the boat up on plane.
Have been looking through the other forums posted here and saw the mention of a couple things but for slightly different symptoms. Any suggestions as to what to look for or where to start would be greatly appreciated?
