bassmasterdude
- Jun 18, 2008
- 3
Helping a friend with an issue missing at high rpm. Runs great at idle and lower rpm but when you get closer to wot it starts to miss. I put my timing light on each plug wire individually and noticed all 3 cyls. were missing intermittently. When you back off the throttle a little the miss will go away. I have changed the plugs, changed fuel filter, tried pumping the fuel bulb, etc. I am leaning towards rectifier, stator or trigger. I did pull each plug wire individually and all 3 reacted drastically so it seems it has to be something common to all 3 cyl. Anyone have more tests for me before we start throwing parts at it? He is taking the boat out tomorrow and is going to disconnect the two yellow wires off the rectifier to at least eliminate that so I won't know until tomorrow if that was it but I have my doubts.
