basstracker2008
- Jan 20, 2008
- 39
Please share your idea about water separator...
I just finish installing Racor Fuel water separator.
I filled up the bowl/filter with fuel before install.
The fuel connection layout is Tank - Hose - Inlet Filter - Outlet Filter - Hose with primer bulb in the middle and valve at end.
Tested by pressing the primer bulb many times, poke the valve but no fuel burst out.
It seems the primer bulb attached after the filter is not making enough suction to draw fuel from the tank into the Filter and off the filter to the primer hose.
Can someone tell the preferred setup? How to test to ensure that fuel is flowing sufficiently to the motor.?
If I have the primer after the filter, I guess I can test it by priming and poking to the valve. If I put the primer before the filter or bet tank and filter, I don't have a way of finding out whether the fuel will travel off the filter to the motor. But I think I can, I'll intall a long hose after the filter and see if the fuel will come out at least. If it does come out then I know I don't have any blockage and that my motor's fuel pump will the job of getting fuel from the filter.
See attached picture.
Please help.....
Thank you all...
Please help.....
Thank you all...
