jdparsons1
- Jun 22, 2003
- 16
I have a 1987 85HP Force. It starts and runs great but it seems like once the engine gets to a certain temp it starts to bog real bad and eventually gets to the point where i have to almost idle back to the dock. Im thinking it runs a good 15-20 minutes at 3/4 throttle before it starts to do this. If I leave it sit for 10 minutes i can start up and it runs great for only about 5-10 minutes. Generally the more i let it cool down the longer it will run good.
I replaced the plugs, plug boots, thermostat and impeller last fall and took it out for a test and still had the problem. Decent compression on all 3 cylinders. This has got to be something electrical but i have no idea how to go about tracking it down. Any recommendations or ideas?
