wbh3569
- Dec 13, 2007
- 28
Hello, I have a 1970 Chrysler 35HP outboard that I am borrowing from a freind and started engine last night to check everything out before taking off accross the lake.
I have the lower unit submerged above the cav. plate and when it starts up there is no water coming out anywhere
like a pee tube etc. to insure that the impeller is OK.
Does anyone know a. if these engines have a pee tube as such (like later model outboards) b. should there be water coming out the small exhaust hole in the rear of lower unit. c. Do they have a thermostat that could be prolonging water flow from coming out exhaust (only ran for about a minute scared I would ruin impeller).
Any input is greatly appreciated.
