After having the head gasket replaced, I took the engine home and couldn't get it started. I took it back to the marine mechanic and after a minute he got it running. We let it run and then I took it home. When I tried to start it, it ran for about 45 seconds and the cut out. I thought it might be sucking air so I wrapped Teflon tape on the fuel line connection where it goes into the plastic gas tank. Still no go. Any ideas?
