Hi all,
I have a 1988 Bayliner Cuddy with a 125 hp Force OB model 1251X8C engine and power trim/tilt.
The previous owner replaced the throttle and cables with an aftermarket kit. Now I have the power tilt toggle on the dash that works just fine, but there does not seem to be trim control wired into the throttle? I know this is a silly question, but is the trim controlled seperately from the tilt? Or do I need to wire the control up to the trim? If so where is the trim relay? (I'm assuming is a control relay seperate from the tilt?) Would there possibly be a schematic for it somewhere on the web? (I know, I've ordered a manual, but I'm impatient)
Thanks for putting up with my questions *cheesy grin*
