Is it possible to convert this engine to a short shaft economically? The motor it is replacing is very similar if not nearly identical. Are parts swappable, like the drive shaft and shift linkage? would it be easier to just build the transom up?
The two motors:
1984 Force 50hp Long shaft Model: 507F4A
Late 60's? Sea King (chrysler) 45hp short shaft Model: VWB27945A
The two motors:
