hello everyone.im having a problem to register my boat i need a vin# or serial# off the motor in order for me to register the boat. in ri you must register hull and then the trailer and also the motor (only outboards). but the problem is that my tag on the side of the mounting unit is so faded out that the numbers cant been read is there anywere else on the motor that might have the vin# or serial# on it or is there anyone out there with a salveged motor that i can read off those vin# is somebody can help me out all i need is a # tag off a salveged motor will do to but it must be off a 1988 85 hp force.thanks
