Good morning all:
Great forum.
I have a 17' Bluefin with a 1988 force 50.
Started it up in the yard this year and it seemed to be running fine.
Hit the water for the first time and it bogged down.
Determined that its only running on one cylinder.
Changed plugs: no difference.
Got the Seloc manual
Tested the rectifier and the stator: OK
Switched the coils and the same cylinder does not fire.
I am hoping it is the CDI box (I have already ordered one)
Best price was boatfix.com.
I did find one wire loose.
White\Green stripe from CDI to Bus bar.
Fixed that: no difference
If that wire was shorting could it have burned out something in the CDI box?
Thanks in advance for any help or suggestions.
PS: Compression checks OK.
Great forum.
