CommanderPleasure
- Jul 20, 2007
- 5
I'm trying to get my newly acquired Chrysler 55hp outboard running. I don't know the last time it was run but figure it was > 1 year and should go through the motor before starting it up. In doing my homework, I learned that my motor is M/N 5571 and built in 1968. I've also read posts from others who have 55hp motors and recommend getting the carb and fuel pump rebuild kits from Napa Auto Parts. For other 55 hp's, the recommended Napa kits were part number 18-7037 ($15 carb rebuild kit) and 18-7806 ($9 fuel pump rebuild kit). I went to Napa today and they actually have several kits. Potential carb kits are: 551HA, 554, 559HA, 559HE, & 558. Potential fuel pump rebuild kits are 18-7806 and 18-7057. Does anyone out there know the correct kit numbers for the Chrysler 5571 55hp motor? Are there any other components that I should service/ replace before starting up the motor? (I'm planning on changing the oil and the small amount of fuel/oil mix in the tank.) Thanks.
