1988 Force 50HP
Motor appears to suddenly slip out and slam back into gear while driving forward. Its literally a split-second bang! It use to do this once in a while but now the once in every 5-10 seconds. Manual suggests it may be jumping out of gear(?) Recently replaced pinion & forward gear (clutch-dog was fine). Is there a specific sequence in fine tuning the shift cable and shift rod?
Thanks
Thanks
