I had to crawl home at about 1200 rpm's because that is all the power I could get out of the engine. I give full throttle and the boat barely moves and then bogs down.
I tried to squeeze the primer bulb, but it was all sucked in. A friend at the marina said I only need to change the bulb.
Is that what caused my problem or is there more to it?
