I got a 15 hp chrysler from the mid 70's and now one connection rod and piston are broken and also one of the 2 cilinders is totally gone.
Somebody gave me a 9,9 chrysler with a good engine in it.
My question is, is it possible to put the engine from the 9,9 on the tail of the 15 hp? and is the difference between the 9,9 and the 15 only the carburator and membrane? or also the bore?
wil it give 15hp again when i put the 15hp carburator membrane, flywheel and ignition(electric starting) on the 9,9 engine?
thank you
greetings from The Netherlands
excuse me for my bad english
thank you
