'94 Pro-Line 170
- Jun 25, 2007
- 6
Last weekend it was running perfect at about 5000 rpms when it started running rough. It wouldn't take the throttle over about 2200 (spit and sputter, no power). Back off and it seems to run better. Came in at 6mph. Never recovered. Held pressure on primer bulb (no change). Inline fuel filter is clear. Seems to be in the top cylinder (removed plug wires one at the time-runs ok without #1, barely runs without 2 or 3. Swapped 1 & 2 plugs, but problem still in top cylinder. I'm looking into the carb, but it is sooooo clean! The others were too when I looked at them a couple of months ago. Planning to re-build fuel pump (can't hurt). I stuck my finger in the intake hole after removing the carb. One reed seems a little sticky, but not hard to push open at all. #1 seems to have good spark (accidentally shocked myself silly). Compression is good in all 3. Don't see any water. What am I missing?
