Re: CHRYSLER 115 cooling flow rate
Welcome to iboats. You know how a lot of water from the garden hose ends-up leaking from the sides of the muffs. To account for the rest is impossible for sure.
Are you having temp-related problems right now, Stoney?
As for proper circulation, the best test is the hand test, or temp sticks.
Feel around for hot spots. There should be no place where it should be painfull at all to touch and hold for 3 seconds .
Another suggestion is to mount a pressure guage to it. As I recall, there should be a threaded plug on top of the block for that purpose (somebody correct me if I'm thinking of later or smaller model Forces), but they almost never installed pressure gauges. A pressure guage is a far better indicator of proper cooling than a temp gauge.And they are relatively cheap. I no longer mess with Force motors, so I gave my manual to someone who does. But outside of the inspection plates, inspection of the cooling circuit resemles an upper tear-down.
Definately a "last resort", even after installing a new impeller.
