Greywolf58
- Oct 27, 2006
- 28
Last weekend my control lever stopped moving all the way forward. When I push forward to go into gear all is well, after it's in gear it stops moving and all I can do is troll along. I've disconected the control cables to check for any binding within the control lever housing. The lever move in all directions without any problem. Next I checked the cables themselves. Both cables moved freely inside the cable housing. I then checked the Tower shaft and found that I could not rotate it by hand but a few cm. Should I be able to rotate the tower shaft any? If so what could be stopping it from moving? I beleive this is where my problem is, but can't seem to go any further in determining what's wrong.
Any help is greatly appreciated.
