Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
130 Chrysler Loss Of Power
  • 130 Chrysler Loss Of Power
    I have a 1977 chrysler 130 4 cylinder outboard. After several passes on the lake I suddenly lost power and had to cruise back to the dock at a snails pace. I recently pulled the lower unit thinking I had broken the drive shaft. Upon inspection of the lower unit everything was intact. It was tuned prior to this happening. Does anyone have some suggestions???
    Re: 130 Chrysler Loss Of Power
    Did the engine get hot?
    Was there water from the tell tale
    Chris Craft Scorpion 230 7.4/ alpha 1
    • #3
      Windy, the motor was not hot. yes there was water from the tell tale.
      • #4
        Spark test with a tester or try running in a tank and start pulling one plug at a time and see if any of them show no difference. My guess is you lost two cylinders or one CD Unit. If spark test works next you need to check compression. A blown head gasket will give similar results.
