Very strange intermittent problem. At idle or just a little above idle, motor looses power and stalls. If I give it full throttle, it will then pick right up and go. Doesn't happen all the time, and there does not seem to be a common denominator as to when it does. I replaced the plugs, stator and power packs. Anyone have any ideas what else it could be? My mechanic seems to think it is electrical, but so far and $1100.00 later the problem is still there. Could it be a fuel pump issue or maybe a coil?
