Greywolf58
- Oct 27, 2006
- 28
Ok, I'm following the instructions from my SELOC repair manual on removing the shif shaft oil seal. It says to pry it out with a screw driver. Do they mean just to pry out the rubber seal or does the metal ring around it also come out? I've started prying out the ruber seal, but it is just breaking apart leaving small pieces of rubber attached to the metal ring around it.
