i386
- Aug 24, 2004
- 3,548
Skip past the first paragraph if you don't want the gory details.
The last time I had the boat on the lake my little Chrysler ran hot. I waited until it cooled off to check it out. It hadn't siezed up which was good. It started right up. While idling there was enough water circulating to keep the engine cool. If I ran it fast enough to plane the boat out, no water came out of the telltale and I could feel the head heating up. Backing it down to idle it would cool right off enough that I could hold my hand on the head so we idled back to the ramp.
I dropped the lower unit today to see if I could locate the problem. The first thing I noticed was the drive shaft was blackend with grease/oil. The second thing I noticed what I think was lower unit lube on top of my pump housing.
There's always been a little water in the lube when I change it and I knew sooner or later I'd need to repair it properly.
Next I removed the 4 screws securing the pump housing. I expected to see a mangled impeller. This was not the case. Sure there were a few cracks so it needs replacing but nothing that would make me think it would just totally fail.
The water tube "grommet" looks like it's got some heat damage. I don't know what one of these is supposed to look like in a Chrysler but it looks nothing like the one in my 'rude. It's hard and does not want to come out.
I think I should replace the seals in the pump housing and the one under the pump housing. My manual says to use a special tool. Is this tool really required? If so where to get one?
There was some grease on the splines on the top of my driveshaft (good), but no o-ring or seal. Shining my light up into the leg I don't see one either.
Just whatever information you can throw at me would be appreciated.
