Hello all. I've been reading this forum for quite some time and finally decided to join after getting some good info on tachs and props. I had fuel leaking from the top carb due to a bad cork gasket. I removed all the carbs to gain access and I tore the top (leaking) carb down as far as I could with the help of my Seloc manual. I backed the idle screw one full turn and the motor started right up and ran well. I wanted to adjust the idle mixture on all three carbs so I made the adjustments but I noticed no change in the motor when adjusting the second carb. I also could not drop the rpms (1100) at idle because I could not turn the main idle screw due to the nut that sets it tight. Anyway when I ran the motor it ran well until I dropped to half throttle. At that point the motor stalled. When I attempted to restart the motor it turned over slowly like the battery was almost dead. I increased the throttle and it started up and ran until I backed off to half throttle. I then adjusted each carb to one full turn from closed and that solved the stall at half throttle problem. The motor still turns over very hard when starting, but it runs well at WOT. It also seems to bog down a little when punching it from a standstill. What could be causing this? Are the problems related? It ran fine until I messed with it. That'll teach me! At least it doesn't leak fuel anymore. Thanks for your help.
