Need some help with my motor not starting,
Running fine lost one cylinder and shortly after lost the other. I did have to replace the plugs pretty often before it quit starting. I have replaced the points and condensors, but still not firing. It is getting plenty of gas, and all the wires seem to be hooked up correctly according to the diagram on the side of the motor.
Can anyone help with this or know where I can find the help? The model number is 355HD. Thanks
