I have a 92 90hp Force with an overheat alarm issue. last year I had the impeller and thermostat changed. Get out on the lake for the first time this weekend. 30 seconds off the dock the overheat alarm sounds for about a minute then stops. ran for another 15 minutes and then the motor quits. wait 5 minutes and start it up again. runs for another 30 minutes no issues.
next day I run for about 1 hour at about 2500 ]RPM. no alarm. Take it out just before nightfall for 30 minutes no alarm. stop for 30 minutes. 1 minute after restart ALARM TURNS ON. stops after 1 minute.
next day run the boat for 1 hour at 2500RPM no alarm. Go to put it on trailer. slip it into neutral and ALARM TURNS ON AGAIN.
new impeller, new thermostat, water is coming in a decent stream out of the 2 exhaust holes. put my hand on the block and could leave it there for about 2 seconds before having to release. I'm stumped.
Any ideas of what to do or check?
Thanks
David
Thanks
David
