I am having a problem with my 1988 Force 125 model# 1251X8A. When shifting from forward to reverse the motor often dies. This makes for a fun time at the dock and loading ramp. I then have a terrible time getting it restarted. It starts like it is flooded. I searched for posts with similar problems and found one that suggested that I replace the fuel pump diaphragm and gaskets. I took the fuel pump apart last fall and everything looked ok. Does this sound like the correct fix for my problem or do I have two separate issues? The first being the shifting problem and the second being the flooding problem. When I am underway the engine runs fine.
Thanks
Thanks
