I have a '96 120hp Force. This weekend it sounded like a "chirp" alarm noise was coming from inside the throttle lever while the boat was idling. If I throttled the motor up, it would change from a continous chirp to an intermittent chirp until at WOT it would stop. If I turned the motor off, then switched the key to "on" without starting the motor, it would be a continous chirp. Any ideas what is going on? If you haven't guessed by now, I'm very new to this boat. Also, the pee hole shoots an intermittent jet at low rpm, but a stronger and stronger one as rpm's increase. I premix the oil in the fuel tank for this motor. The motor runs good, but is somewhat cold natured, but the guy who sold it to me says it needs a tune up. Any help would be appreciated.
